05 neon fog light replacement
Old Aug 2, 2011 | 06:26 PM
ryman117's Avatar
ryman117
Default 05 neon fog light replacement
hello all, im just curious if anyone knows the quickest way to replace the fog lights on the 05 neons, because up north in canada they are also the daytime running lights and in order for it to pass safety i need to replace the bulbs and the book says its an 899 bulb. if annyone can verify that and let me know the quickest way it'd be much appreciated!
Old Aug 2, 2011 | 11:59 PM
hemi4spd's Avatar
hemi4spd
u can use a 893 or 880
Old Aug 3, 2011 | 12:25 AM
darthroush's Avatar
darthroush
Section Moderator
Here's from a site that sells bulbs:
880 = 884, 885, 892, 893, 899 have same base PG13, different wattage. These are single filament bulbs and use as foglight bulbs.
The easiest way to verify is to pull the old bulb that you have to replace anyways and look at the number.
Old Aug 3, 2011 | 11:40 PM
ryman117's Avatar
ryman117
alright but what is the easiest way to get the foglight out.... pull the splash guard back and use a ratchet and undo the bolts? or does anyone know of a faster/easier way?
Old Aug 4, 2011 | 01:05 AM
leprechaun1874's Avatar
leprechaun1874
Should be able to remove splash guard and twist bulb out, kinda like the headlights do.
