clutch issues!?!?!?!?!
Old Aug 21, 2011 | 12:31 AM
ralphg21's Avatar
ralphg21
Default clutch issues!?!?!?!?!
guys im new to this dodge neon.......so ok i bought this dodge neon rt 2001 167k miles........cars drove fine only issue was over heating finally came to the conclusion bad thermostat and we fixed that but now i was driving it home comming off the freeway i jus cruised it until the stop sign got to the stop sign shifted into first and it got real stiff and the car shook...... tried to drive and as i pushed the gas and let go of clutch the car shuddered again...when into 2nd and same thing the car shudddered as i shifted gears like sputtering the first few miles then stops until i shift again and it sputters again ...... the car never did this before i had it a week until this happpened.... what could it be?!?!?!? and ideas would help... thanks and its throwing these codes p1684 and p1685...how do i get those fixed?
Old Aug 21, 2011 | 05:46 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
Doesn't sound like a clutch, sounds more like a engine misfire.
Old Aug 21, 2011 | 06:36 PM
darthroush's Avatar
darthroush
Section Moderator
P1684 is meaningless. P1685 is an "invalid SKIM key." You can start and drive your car though, so I'm not sure why that code is showing up.
