2004 RT with rear end chatter
Old Sep 17, 2011 | 05:08 PM
tekknyne's Avatar
tekknyne
Default 2004 RT with rear end chatter
Hello,
I just recently replaced the rear struts in my neon thinking it would take care of this chatter coming from the rear end- it did not. Any thoughts on what it may be? The noise sounds like a squeaky vibration/chatter only when I hit bumps.
Old Sep 17, 2011 | 05:20 PM
tekknyne's Avatar
tekknyne
It's only coming from the passenger side. The car rides great, but the sound is pretty gnarly. When I replaced the struts, I made sure everything was tight.
Old Sep 17, 2011 | 06:10 PM
darthroush's Avatar
darthroush
Section Moderator
It could be bad rear control arm bushings. Might want to check those out.
Old Sep 17, 2011 | 06:59 PM
leprechaun1874's Avatar
leprechaun1874
Also can check your hub.
Old Sep 18, 2011 | 11:58 PM
chew*'s Avatar
chew*
My car makes the same noise, usually replacing the strut mounts along with the struts is a good idea. That might be your issue.
Old Sep 19, 2011 | 03:32 AM
darthroush's Avatar
darthroush
Section Moderator
Ah yeah. The strut tophats.
Old Sep 19, 2011 | 10:32 AM
AnthemBassMan's Avatar
AnthemBassMan
-Yeah, I'd definitely replace the strut mounts. I replaced the rear suspension on my Mother-in-law's '92 Toyota Paseo that was sagging and was making all kinds of noises when she was driving. This is what the strut mount is supposed to look like.
-And this is what it was like when I pulled it from the car. Now I doubt that yours are this bad, but if the bearing plate wears out, you'll get some squeaking and knocking when going over bumps. Especially if you're turning into a parking lot.
L8R,
Matt
Old Sep 19, 2011 | 02:02 PM
darthroush's Avatar
darthroush
Section Moderator
The good 'ol rust-belt states! That's crazy!
Old Sep 19, 2011 | 04:54 PM
AnthemBassMan
-You better believe it! They use more salt on the roads here than McDonald's does on all of their french fries! This is the strut when I pulled the whole unit out. I showed her this and said "I think I found your problem!" Her jaw just about hit the floor.
L8R,
Matt
Old Sep 21, 2011 | 02:48 PM
tekknyne's Avatar
tekknyne
Thanks all so much for the replies. Now the sound has evolved into a cracking/popping and I'm quite sure its coming from up inside the wheel well. I'll do the sway bar bushings first since they are only $15 for a set at autozone. If that doesn't help, I'll try the strut mounts.
Thanks again!
