03 neon wont start
Old Sep 23, 2011 | 10:48 AM
Zanko's Avatar
Zanko
Default 03 neon wont start
Ok so I replace my cam shaft sensor and neutral safety switch (auto) in my car got it together ran and shifted fine. I seen on of the vacuum line had come loose. So I turned the car off and connected the vacuum line. Now it won't start. Any ideas why? Also the shifter is really stiff.
Old Sep 23, 2011 | 11:17 AM
Zanko's Avatar
Zanko
Update will only start in neutral and not in park.
Old Sep 23, 2011 | 01:59 PM
darthroush's Avatar
darthroush
Section Moderator
Is any of the wiring to the neutral safety switch bad?
Old Sep 23, 2011 | 06:12 PM
chew*'s Avatar
chew*
Here's the 2000 2.0L starting circuit, should be same, I will dig out my later model disc later and see if it differs but it shouldn't.
Old Sep 24, 2011 | 10:43 AM
Zanko's Avatar
Zanko
I didn't see any exposed wires or cuts in the wire. And also the shifter is really stiff and will only start in neutral and not drive.
Old Sep 24, 2011 | 09:10 PM
22mopar22's Avatar
22mopar22
41te trans? that's a big job to change PRNDL switch. which would explain the stiff shifter.
