knocking noise at idle.
Old 11-15-2011, 02:53 AM
chew*'s Avatar
chew*
chew* is offline
Originally Posted by brhodes
After a little more research, the only 2.0 in a PT cruiser I can find is in a non-US version. Most of the others came with a 2.4, or 2.2, from what I can see. No valve-train parts look to be interchangeable at all.
Apparently the 2.4 and also 2.7 v6 are all interchageable with the sohc neon.
The diff is the oilin holes, the 2.7 has a smaller hole directed at cam, the 2.4 pt rocker has a larger hole that just splashes.
Old 11-15-2011, 08:02 AM
brhodes's Avatar
brhodes
brhodes is offline
I don't know what those other two rockers are out of, but that one on top appears to be from a DOHC 2.0, which is, yes, interchangeable with a 2.4. The SOHC 2.0 is not.
Old 11-15-2011, 11:17 PM
chew*'s Avatar
chew*
chew* is offline
Yep realize that now.
I pulled an engine apart real quick to see what you were referring to.
Quick Reply: knocking noise at idle.
