Climbing Idle after spark plug change?
Old Dec 10, 2011 | 04:04 PM
VincibleBiscuit's Avatar
VincibleBiscuit
Default Climbing Idle after spark plug change?
So basically i had a fouled spark plug which was causing my car to not run.. Changed all 4 spark plugs and now my car will run but the idle starts out high and the RPM seems to continually climb higher and higher as it idles. Engine sounds normal so i dont know what happened, suggestions?
Old Dec 11, 2011 | 04:57 AM
darthroush's Avatar
darthroush
Section Moderator
Did you change anything else? Bump anything, remove anything?
Old Dec 11, 2011 | 11:24 AM
VincibleBiscuit
Well i looked around the engine bay again this morning and apparently somehow my crankcase ventilation tube got broken - Could that be the cause of it?
Old Dec 11, 2011 | 04:51 PM
darthroush's Avatar
darthroush
Section Moderator
Can't remember if that'd be a vacuum leak or not. If you plug it with your finger, is there suction?
A vacuum leak would cause what you are describing.
Old Dec 11, 2011 | 10:24 PM
VincibleBiscuit
Yup its got suction so that has to be the problem, Will fix it and let you know if it works, Thanks!
