Do I need to replace coolant?
Old Dec 18, 2011 | 02:35 PM
nini09's Avatar
nini09
Default Do I need to replace coolant?
I have 2005 Dodge Neno and mileage is 46000. Someone told me your coolant needn't replace because it is organic.
When do I need to replace my coolant? How can I check my coolant condition?
Old Dec 18, 2011 | 02:46 PM
darthroush's Avatar
darthroush
Section Moderator
You can check your coolant's condition with a multimeter (for electrolysis) and a basic coolant tester (for dilution level) from most places that sell coolant. The factory coolant is supposed to last some time. However, I still change it according to most "normal" recommendations of 2 to 3 years, or about 30,000 miles.
Old Dec 19, 2011 | 03:26 PM
nini09's Avatar
nini09
Thank you, darthroush.
I checked my coolant and manual. My coolant look like Mopar HOAT. It can last 5 years/100,000 miles and color is red. Is it ok if the coolant is replaced in 2012 or 2013?
miles
Old Dec 19, 2011 | 06:06 PM
darthroush's Avatar
darthroush
Section Moderator
I'd check it for electrolysis with a multimeter, and if the level is fine, you could wait a bit more. When you go to change it, if you want to go with the regular green coolant, just be sure to use a cooling system cleaner to clean out the HOAT. Good to clean the system out a bit anyways.
Can electrolysis be measured? At the heart of the electrolysis issue is it's measurement. If it can be measured, it's presence can be verified, which is extremely important when we are removing the electrolysis.
It is a simple measurement, a digital VOM is needed, simply attach one lead to the negative battery post, and with the other, dip it in the coolant. Should read zero right? Maybe just a bad ground? Try this, remove a battery post. Still reading .3v or above? It's not a loose ground your after.... You better keep reading.
Factoid #2 If you have a reading of more than .3v, (three tenths), you have electrolysis. Generally, a reading of hundredths (.01-.09v) is below the action level, and will not result in aluminum failure.
I've seen 0.05 volts means it's a good time to change the coolant as well.
Old Dec 20, 2011 | 07:46 PM
nini09's Avatar
nini09
