fires but wont stay running
My daughter has a 2000 neon with 65,000 mile, sohc automatic trans. car suddenly died yesterday and after looking at it, I was able to get it to start, but extremely rough idle and need to stand on the gas pedal to maintain even 1000 rpm. I have spark, gas and air, so im leaning towards timing, crank sensor or cam sensor.
anyone have these symptoms before and where should i start my search? this is the first dodge i have ever looked at and could use some advice.
thanks in advance.
thanks in advance.
cant look at the cat to see if it glows because it wont start. replaced the upstream O2 sensor and fresh plugs. it starts to fire up, but then stalls. unplugged the cam sensor to see if it would start, and that made it worse. i have read the crank sensor is problematic, but not sure where to turn next. any suggestions??
P0171 is there because of P0132/P0133 most likely. P0132/P0133/P0134 doesn't 100% mean a bad sensor, but much more likely bad wiring. Replacing any sensor if the sensor wiring is bad will result in the same problem, obviously. The problem is most likely going to need a bit more intermediate/advanced troubleshooting like steak59 suggests.
Trending Topics
Do you have only a Simple Code reader or the more expensive OBD2 scanner?
If you suspect the Crank sensor, you can monitor the Engine RPM to be sure.
also look at TPS signal, % open and voltage.
Since it starts now, do you still have to Floor it to keep it running? or it will idle with slight throttle?
