So what is this special tool L-4553
Old Feb 7, 2012 | 11:59 AM
TejasMtnBiker's Avatar
TejasMtnBiker
Originally Posted by Slim57
No, sorry to say I do not know. I hoped that if TejasMtnBiker removed pan fr his 3 speed, he could inform the rest of us.
I prob won't have it off in the next 2weeks or so, works gotten in the way again limiting my repair time to less then an hour nightly or less, after a 16 hour work day
Old Feb 7, 2012 | 04:33 PM
darthroush's Avatar
darthroush
Section Moderator
Oh. Got ya. I looked at the manual and agree it looks like a bit holder with a torx bit.
Old Mar 9, 2012 | 10:28 AM
gtomangto's Avatar
gtomangto
Default special tool
I just use a T25 torx bit
Old Mar 15, 2012 | 11:34 AM
TejasMtnBiker
So I did my trans fluid & filter change, yea I'm glad I had a heavy duty T25 these 2 screws were in super tight, a cheap tool would'a just stripped. But it definitely needed it, shifts so much nicer now when under higher rpm.
Old Apr 29, 2019 | 11:06 PM
ehbowen's Avatar
ehbowen
that is to remove the auto transaxle filter bolts? Is it a torx or metric allen wrench? Can anyone say what type of fasteners hold the strainer/filter to the valve body?
Also, is there an O ring or gasket between the strainer and valve body?
The car is a 2002 Neon with SOHC 2.0L 4 cylinder, probably most common power plant.
Thanks, Slim
I just changed the fluid and filter in my 31TH (A404) transmission in my 1999 Voyager (2.4L I-4) today. The filter was held in with two T-25 Torx screws, so it appears that "Tool L-4553" is just a heavy duty T-25 Torx bit.
