Aftermarket Tachometer
I actually looked on Sunpro's website, and it looks like this adapter actually won't work with the Neon.
Cheapest isn't always the best option though. I would recommend an autometer tach.
I stand by my original statement. It lists compatibility with the first gen Neon, because it has a wire coming off of the PCM that has the correct tach signal. The adapter is still incompatible.
What performance difference would there be if I were to get a cheap tachometer with a 2 cylinder rating? What autometer tach do you recommend?
Am I missing something? I believe that unless you've made SERIOUS modifications to your Neon, the only engine option you have is a FOUR cylinder. So if you're looking for a two cylinder tach, it probably won't work or will give you inaccurate results. Also, I do have a related question. Is it known, for a fact, that a Neon without the tachometer cluster will still give a tach readout? Mine has a mtx without the tach and if I can get a tachometer for it, that would be awesome.
If you mean by swapping clusters, then yes. If you mean by adding a tach, then still yes.
