01 Neon fouling spark plugs
Old Mar 8, 2012 | 09:00 PM
silver1r's Avatar
silver1r
Default 01 Neon fouling spark plugs
Hey guys, this is my first post so please bear with me. I have a 01 neon with the 2.0 liter. It is 100% stock. Four times within the last 2 months, I will go start my car to go to work and it will fire and continue to turn over and hits every once in a while. So I usually drive my other car to work when this happens. So a few hours later I pull the plugs and clean all the fuel off of them and it fires up. But it will not start until I clean the plugs. What I mean by that is, I can't try it in the morning and then 8 hours later, it will still be fouled out. I hooked up a genisis and all the sensors seam to be reading fine. Coolant temp is spot on, map sensor is working fine and I also pulled the fuel rail and none of the injectors are leaking. If you have any ideas, that would be great. Thank you.
Old Mar 8, 2012 | 09:10 PM
buddhaman's Avatar
buddhaman
When was the last time you changed your plugs/wires? Have you checked your fuel pressure at the rail?
Old Mar 8, 2012 | 09:18 PM
silver1r's Avatar
silver1r
Plugs and wires were replaced last sat night. I have not checked fuel pressure just because it seems to be getting to much fuel. I can check it tomorrow. Would that cause my problem? Two more things, it only does it when its 30 or below and the fuel pressure regulator has been bad for about a year (have to prime the pump with key to build pressure when sitting for few hours). I don't know if that helps
Old Mar 8, 2012 | 09:47 PM
buddhaman's Avatar
buddhaman
That could be a reason it's getting too much fuel and if the Intake Temp Sensor is going wacky it'll have an effect on how much fuel the injectors pump out.
Old Mar 8, 2012 | 09:56 PM
silver1r's Avatar
silver1r
ok, I will check fuel pressure tomorrow. My intake temp sensor is working also. Thank you for your help
Old Mar 8, 2012 | 10:14 PM
silver1r's Avatar
silver1r
Oh, what should my fuel pressure be, just so I can compare readings?
Old Mar 9, 2012 | 09:19 AM
silver1r's Avatar
silver1r
So i hooked up a fuel pressure gauge and it was running at 70psi at idle. Is that too high?
Old Mar 9, 2012 | 11:08 AM
silver1r's Avatar
silver1r
No ideas?
Old Mar 9, 2012 | 01:12 PM
chronoboy's Avatar
chronoboy
i dont have the same pluggs issue as you but i do have the same problem of if my car sits for a day or two or awhile i have to prime the fuel pump pretty much just wait three-five seconds before i turn the key all the way, never bothered me much cause i didnt mind the short wait and if you drive it daily it dont do it but i always kinda wonder why it dont hold pressure over time but not anough to investigate it, so hopefully somebody knows, cause i would like to know that answer.
Old Mar 9, 2012 | 01:32 PM
silver1r's Avatar
silver1r
Me too, but no one knows what the fuel pressure should be in a 01 neon. Should have know better to buy a chrysler, never again. What a pos
