2000 Dodge Neon Vacuum Lines
Old Mar 12, 2012 | 04:02 PM
jnmgrizzle's Avatar
jnmgrizzle
Unhappy 2000 Dodge Neon Vacuum Lines
I replaced my head gasket and intake gaskets on my 2000 dodge neon and now have it all back together and cannot find where the opposite end of the vacuum lines connect. I know they start at back and side of engine. any help or visuals would be greatly appreciated! thanks
Old Mar 13, 2012 | 04:29 AM
darthroush's Avatar
darthroush
Section Moderator
Quick Photoshop diagram....
Old Mar 13, 2012 | 11:14 AM
jnmgrizzle's Avatar
jnmgrizzle
ok i found that but found another that came disconnected...the one that runs right in front of the air box where does that connect to?
Old Mar 13, 2012 | 01:41 PM
darthroush's Avatar
darthroush
Section Moderator
That one from the throttle body goes to the purge solenoid.
Old Mar 13, 2012 | 11:53 PM
jnmgrizzle's Avatar
jnmgrizzle
Ok i got the vacuum lines figured out who ever had the car before me had them disconnected....I got it running but now the timing is off i have the cam gear so the little nipple is up and cylinder 1 is up
Cylinder 1 i assume is
1 3 4 2
or am i doing something wrong its running really rough any suggestions on what to do?
Old Mar 14, 2012 | 12:03 AM
jnmgrizzle's Avatar
jnmgrizzle
Forgot to mention its an sohc, not a dohc. that may be important
Old Mar 14, 2012 | 11:12 AM
jnmgrizzle's Avatar
jnmgrizzle
when in park engine will rev low then high and stay in this pattern. (don't have a tach for the rpms)
Old Mar 14, 2012 | 04:56 PM
jnmgrizzle's Avatar
jnmgrizzle
yea no tach and yea its like i keep steppin on and off the gas.
Old Mar 14, 2012 | 06:45 PM
darthroush's Avatar
darthroush
Section Moderator
It runs rough, or it idles up and down...or both? That idle problem sounds like a vacuum leak. Are there any tears in the accordion tube of the intake?
Old Mar 14, 2012 | 07:02 PM
jnmgrizzle's Avatar
jnmgrizzle
No tears, it idles up and down
