Whining noise at 30mph while on gas.
Old Apr 11, 2012 | 10:16 PM
Moparkyle's Avatar
Moparkyle
Default Whining noise at 30mph while on gas.
I hear a whining noise at 30mph only, and when i let off the gas it goes away.
Wondering if this is a normal phenomena with Neons?
Old Apr 13, 2012 | 06:56 PM
Moparkyle's Avatar
Moparkyle
All I need someone to do is drive their car at approx. 30 mph and see if they hear this noise.. lol.
Old Apr 14, 2012 | 04:51 AM
darthroush's Avatar
darthroush
Section Moderator
Any kind of whining is not normal on any car.
Old Apr 14, 2012 | 06:16 PM
Moparkyle's Avatar
Moparkyle
I'm assuming it must be something inside of the transmission/differential. In which case I'm not going to worry about it.
I just remember driving a Plymouth Breeze and hearing the same noise.
Old Apr 14, 2012 | 07:46 PM
joester's Avatar
joester
My '01 makes more of a whistling noise from under the hood. No air leaks to be found. I'm assuming there might be a hairline crack inside the intake manifold near a point of high air speed that makes the noise. I inspected while I had it apart and found nothing.
The noise mine makes is dependent on the engine load and RPM, but basically occurs around 30-35 MPH on a flat road.
Now that I'm thinking about it, today was the first real time I drove the car after replacing the head gasket and just about every other gasket related. I do not recall hearing it today.
