Replace or flush coolant?
Old Apr 14, 2012 | 02:43 AM
nini09's Avatar
nini09
Default Replace or flush coolant?
I have Neon 2005. It need replace or flush coolant. Is it good enough if I only loose drain fitting and let coolant drain out? Don't flush coolant completely. Is it Ok? It look like flushing is complicated.
Old Apr 14, 2012 | 04:50 AM
darthroush's Avatar
darthroush
Section Moderator
Flushing isn't that complicated. Once you drain the coolant, you simply leave the drain valve open, turn the car on and the heater to high, and stick your hose with running water into the radiator opening and let it run for about 5-10 minutes. Turn the car and hose off, let that water all drain out, close the valve and refill the radiator. Done.
Old Apr 14, 2012 | 02:09 PM
nini09's Avatar
nini09
Thank you, darthroush, for replying. My car is in public parking lot and I can't get running water. That's why I say flushing is complicated.
Old Apr 14, 2012 | 05:52 PM
darthroush's Avatar
darthroush
Section Moderator
In that case: go pick up a few of those 2.5 gallon jugs of distilled water. Drain the coolant, close the drain valve and then fill it up with the distilled water and run the engine and heater. Then continue on from there.
Old Apr 14, 2012 | 06:12 PM
Moparkyle's Avatar
Moparkyle
How bad does your coolant look?
Old Apr 15, 2012 | 01:58 PM
nini09's Avatar
nini09
Thanks for replying.
From outside coolant reservoir, coolant's color still is red.
Old Apr 15, 2012 | 06:05 PM
darthroush's Avatar
darthroush
Section Moderator
I'm taking it the Dodge coolant is red? Horrible color especially when the red transmission fluid can mix with it. IMO, flush it and fill it with regular green G05 coolant.
Old Apr 16, 2012 | 03:14 PM
nini09's Avatar
nini09
I can try to flush it. But I really want to know how bad if I only replace coolant in radiator?
Old Apr 16, 2012 | 04:32 PM
darthroush's Avatar
darthroush
Section Moderator
You'll still have dirty, old coolant everywhere else. Your car, your call. IMO, spend the extra 10 minutes and do it right.
Old Apr 17, 2012 | 06:38 PM
Moparkyle's Avatar
Moparkyle
Yeah it's like a pinkish color. I have MOPAR in my car.
