2001 Neon Rough Idle
Old Jun 5, 2012 | 10:01 PM
ryanlunchbox's Avatar
ryanlunchbox
Default 2001 Neon Rough Idle
Hey Guys!
Ive been trying to figure out why my 2001 Neon rough idles and shakes. Steering wheel vibrates whole car vibrates and its pretty annoying. Car idles steady at around 700 rpm while in drive and still shakes but sometimes not as bad while in neutral. When you turn on the AC it gets worse. Car never stalls and always starts no problem.
Ive taken the following action so far:
1. Replaced IAC Sensor and cleaned throttle body with Cleaner.
2. Replaced Plugs and wires.
3. Ran seafoam through fuel system.
4. PCM isnt throwing any codes
5. Replaced air filter
Any ideas? I was going to replace TPS sensor next not sure if it would be a waste of money or not...Any help would be greatly appreciated!
Thanks
-Ryan
Old Jun 6, 2012 | 10:50 AM
TejasMtnBiker's Avatar
TejasMtnBiker
vaccum line leak & bad motor/transmission mounts made mine do this exactly, find your vac or pcv leak 1st, easier to find when it's hot weather and the bad lines really reflect their age. Mines a 2000, always garaged and all the lines were on their last leg.
Old Jun 6, 2012 | 09:32 PM
Moparkyle's Avatar
Moparkyle
Trans/Motor mounts will make the car shake in D/R/and park. They will also make the car seem as if it is running poorly.
Old Jun 6, 2012 | 11:46 PM
Shaun.Perry's Avatar
Shaun.Perry
2nd the above comment. Motor mount and trans mount cost 70 bucks with tax from autozone. Duralast brand and takes all of about 2 hours to do both. World of diffeence.
Old Jun 8, 2012 | 07:38 PM
TejasMtnBiker
and it seems like to me on my 2nd set of mounts if I keep them clean of grease and oil they last longer, pta to wash them too but about to hit a year on this 2nd set I put in from azone
Old Jun 9, 2012 | 01:22 AM
fhadso's Avatar
fhadso
Mine did that right before my timing belt broke. Have it checked ASAP.
Old Jun 9, 2012 | 10:55 PM
Moparkyle's Avatar
Moparkyle
The mounts in my car are not so good.
