problem
Old Aug 21, 2005 | 07:06 PM
jjayjjay71787's Avatar
jjayjjay71787
Default problem
right now i know i need a wheel alignment but when i drive my brakes r messed up i try to step on the brake n the car dont stop unless i step the pedal all the way to the floor i know its not my brake fluid cuz its full
Old Aug 21, 2005 | 07:28 PM
Fhantazm's Avatar
Fhantazm
Default RE: problem
Possible pads or air in the system.
Old Aug 21, 2005 | 07:49 PM
jjayjjay71787
Default RE: problem
the pads werent change that long ago
Old Aug 22, 2005 | 02:37 PM
hemipower1984's Avatar
hemipower1984
Default RE: problem
if it has rear drum brakes they could be out of adjusment also pistons in calipers could binding up. be sure there are no leaks and try to bleed your brakes. start right rear then left rear right front then left front.
Old Aug 22, 2005 | 07:15 PM
jjayjjay71787
Default RE: problem
i just checked my car n the clip that holds the brake pad in place was bent i had to hammer it str8
