I need Help. =(((((((((
Old Jul 10, 2012 | 06:49 AM
FireFighter22bho's Avatar
FireFighter22bho
Well I checked everything, even for a vacuum leak, nothing. Apparently it's my fuel pump and fuel filter. It really suck cuz now I'm gonna put more money into this damn thing.......
Old Jul 10, 2012 | 08:53 AM
FireFighter22bho
Does anybody know any good websites to get cheap neon parts?????
Im kinda broke right now and cant afford ****!
Old Jul 10, 2012 | 07:43 PM
darthroush's Avatar
darthroush
Section Moderator
Being in Germany is the problem. The shipping will probably be insane. Might check something like eBay and see if someone offers worldwide shipping for a reasonable amount.
Old Jul 10, 2012 | 08:01 PM
jw11432's Avatar
jw11432
for parts, ive been using rockauto. they've got some great prices on a lot of stuff.
truthfully, your symptoms don't sound like a faulty fuel pump.
check and make sure all your grounding straps are getting a good connection (never hurts to unbolt them, and make sure they're clean) engines can do pretty wacky things with a bad ground. all of those sensors on your list share the same sensor ground wire. doing some continuity tests to make sure there isn't a short in it would behoove you, as well as looking into the power distribution center to make sure there aren't wires that are shorting, which could cause excessive voltage. not sure if this is possible, but while your engine is running, check to make sure your alternator(generator) isn't overcharging.
as for checking for vac leaks, how i like to do it is using a fresh can of starter fluid and spraying small spurts around suspect areas. if theres a leak, you will hear your engine surge. you can also use a propane canister (not lit! lol) to check for leaks. either method, you just spray/direct gas around vac lines and wait to hear engine surging. the intake boot is probably a commonly overlooked source of leaks; unmetered air can change the running condition drastically. i accidentally forgot to hook mine up a couple weeks ago, and i got scared cuz it was running so crappy lol.
Old Jul 10, 2012 | 11:41 PM
darthroush's Avatar
darthroush
Section Moderator
RockAuto does have international shipping...
Old Jul 11, 2012 | 05:19 PM
FireFighter22bho
I found the problem today and fixed it!! it was my (TPS) throttle position sensor. Now the baby runs fine juhuuuuuuuu!!!!
