fuse?
Old Aug 4, 2012 | 02:43 PM
lgmn69's Avatar
lgmn69
Default fuse?
I have a 2004 neon sxt, the radiator went so I replaced it. Now when I try to start the car, it won't start and I see the word fuse flash on the odometer. I check the fuse box by the drivers door and the regular fuses under the hood in the module box or what ever it is. Has anybody run into this before? Or does anybody have any suggestions?
Old Aug 4, 2012 | 03:01 PM
fhadso's Avatar
fhadso
Radiator fan relay?
Old Aug 4, 2012 | 03:09 PM
lgmn69's Avatar
lgmn69
any idea where i would find it?
Old Aug 4, 2012 | 03:40 PM
darthroush's Avatar
darthroush
Section Moderator
Did you hook all the grounds back up? I don't recall unhooking any during my radiator replacement though. It can be an actual fuse problem, it can be a ground problem, it can be a dome light or trunk light that is out. The only time my car wouldn't start and fuse was displayed in the cluster was when I missed reconnecting an engine ground.
Old Aug 4, 2012 | 03:49 PM
lgmn69's Avatar
lgmn69
only unhooked 2 grounds during the work and both are hooked back up. all lights work aswell
Old Aug 7, 2012 | 02:02 AM
darthroush's Avatar
darthroush
Section Moderator
Here's from the FSM:
The display may show the odometer mileage, the trip odometer mileage, P-codes, “no buS” for loss of bus communication, and “FUSE” for loss of battery fuse.
I'll add this one because I forgot about it despite also having it happen to me:
If the cluster determines that there is not 8.0 volts at the battery input, then the cluster shall alternately display “FUSE” and the odometer mileage.
The battery could be going out, or has gone bad, or there is still a fuse issue. I know the dome light and trunk light (if equipped) both act as inline fuses as well. This is a problem in which, unfortunately, you just have to go over everything. There is no for sure, exact cause.
Old Aug 7, 2012 | 10:28 PM
lgmn69's Avatar
lgmn69
gonna check the battery for an inline fuse this weekend. a guy I work with also suggested it
Old Aug 7, 2012 | 11:42 PM
darthroush's Avatar
darthroush
Section Moderator
There's no inline fuse for the battery. One of the power wires goes from the PDC to the positive terminal and the other from the starter to the battery.
Old Aug 11, 2012 | 03:15 PM
lgmn69's Avatar
lgmn69
well tried unhooking the negative terminal and reseting the computer but that didn't work. also both teh dome light and the trunk light both work so now i guess i gotta start testing relays
Old Aug 11, 2012 | 04:21 PM
buddhaman's Avatar
buddhaman
Did Dodge change the PCM location on NCG cars from the location 2nd gen non-NGC's? The PCM in my '00 is right next to the radiator/fan. Wouldn't hurt to find out if the connections are tight on the PCM.
