broken timing belt
Old Aug 20, 2012 | 10:20 AM
Oscar Sanchez's Avatar
Oscar Sanchez
Default broken timing belt
My timing belt broke and i replaced it but car wont start. I was thinking i have some bent valves. I tried using an old rusty compression tester but it wont give me a reading in any cylinder. Is there any other way to know if i have bent valves?? Btw am trying to start the car with PS and alt disconected atm is this causing to not start?
Old Aug 20, 2012 | 11:13 AM
Goromous's Avatar
Goromous
PS and alt wouldn't make a difference. As long as the batter is charged. You can rent a compression tester at Autozone or Oreilly's. What's it doing when you turn the engine over?
Old Aug 20, 2012 | 12:04 PM
Oscar Sanchez
I went to autozone and rented a compresion tester and am still getting 0 compression on all 4 cylinders maybe its right or i might be doing this wrong last time i tried to start the car turned and i could see the belt moving without an issue but this last time it made a sound something it had not done before. And right after that i removed a spark plug to try the new tester i could see smoke coming out of the spark plug hole. Am running out of options and i really want to make sure its the valves before removing the head
Old Aug 20, 2012 | 12:17 PM
cheapez's Avatar
cheapez
the valves may have damaged the pistons too.
Good luck to you.
Old Aug 20, 2012 | 12:35 PM
cheapez's Avatar
cheapez
The only thing the timing belt would do when it broken is: the pistons hit the valves. So you better believe you have bent/broken valves.
Then you can check to see if the timing belt when broken, it fled off, and did hit something outside of the engine like electronic wires, ...
Old Sep 20, 2012 | 10:37 AM
03neonRT's Avatar
03neonRT
Yeah, if the belt actually snapped, then your valves are most likely bent. Replacement valves and retainers will probably $75-$150 depending on which brand you go with. You'll also need to rent a couple tools to get the job done. The pistons are probably fine...maybe some scuffing on the domes, but otherwise, I can't imagine them being damaged in any significant way.
Old Sep 21, 2012 | 02:18 AM
Oscar Sanchez
I spent 324$ on valve job and labor. Installed and worked right away. Replaced cam sensor and water pumo while at it. 150k miles. Engine feels waaaaaaaaaayy better than before it feels like a complete diff car
Old Sep 21, 2012 | 08:43 AM
03neonRT's Avatar
03neonRT
Good deal. Amazing what a car feels like with so many new parts
