OBD Plug Dripping oil
Old Aug 27, 2012 | 11:32 AM
steve die's Avatar
steve die
Default OBD Plug Dripping oil
Hello, I have a 2000 Automatic Neon 2.0 engine and over the last few months I've noticed a pool of oil (not dark oil, on the yellow side) dripping from the OBD plug and onto my rubber mat. It is steadily getting worse. I was wondering where on earth it could be coming from. I looked with a flashlight and saw no visible signs of a leak running towards it other than immediately to the left of it which was only slightly wet. Any thoughts on that?
Old Aug 27, 2012 | 11:09 PM
Moparkyle's Avatar
Moparkyle
Obd??
Old Aug 28, 2012 | 02:06 AM
bwdakrt's Avatar
bwdakrt
Sounds like you have a power steering pressure switch leaking and the PS fluid is wicking back thru the wiring harness to the OBDII plug under the dash. The switch should be located on the PS line close to the pump. Replace the switch if it is leaking.
Old Aug 28, 2012 | 07:10 AM
darthroush's Avatar
darthroush
Section Moderator
Interesting thought, but even if the fluid somehow managed to wick upwards, through the firewall and back down to the OBD-II port, the fluid is red (they use transmission fluid as PS fluid). It sure sounds like something is running down the lines, as odd as this problem is. The brake fluid reservoir is above those lines and the fluid is a lighter yellow (once it is used a bit).
Old Aug 28, 2012 | 07:15 AM
bwdakrt's Avatar
bwdakrt
Remove the dip stick from the PS fluid reservoir and check the color on a white paper towel. Tranny fluid can be used in the PS but some still have the standard yellowish PS fluid. A drop or two on a white paper towel will answer the question.
Old Aug 28, 2012 | 08:05 PM
Moparkyle's Avatar
Moparkyle
Neons use ATF +4 as standard P/S fluid.
I had no idea that he was actually talking about the OBD port.. lol that's strange.
Old Aug 29, 2012 | 03:20 AM
darthroush's Avatar
darthroush
Section Moderator
If it is a standard PS fluid, someone flushed the system and swapped fluid types. All 2nd Gen Neons come from the factory with transmission fluid as the PS fluid. It is something that should be checked, though I don't think a paper towel is needed to tell the difference between an almost clear fluid and a bright red one.
It is indeed!
Old Aug 29, 2012 | 07:05 AM
Moparkyle's Avatar
Moparkyle
Oohh yeah we're talking about a 2000 Neon here.. I have a 3rd Gen 03 and mine specifies for ATF +4.
Old Aug 29, 2012 | 12:56 PM
earlyre's Avatar
earlyre
3rd gen neon? isn't that the dart?
Old Aug 29, 2012 | 03:57 PM
darthroush's Avatar
darthroush
Section Moderator
Caliber
