00' to 05' Interchange
Old Sep 8, 2012 | 10:13 PM
fhadso's Avatar
fhadso
Default 00' to 05' Interchange
So I'm really into buying this nice '05 SXT. I currently have a '00 ES. I want to keep my short throw, my head unit, and maybe my CAI. a) Is there a difference in the linkages of the '00-'02 models and the '03-'05 models? b)Would I be able to just swap the head units? The '05 is bone stock, so I don't know if I could just swap it with the wiring harness and everything. and c) Is there a difference in the intakes that would make the CAI I have not fit?
Old Sep 20, 2012 | 08:40 AM
03neonRT's Avatar
03neonRT
Is the head unit an aftermarket, or an upgraded Dodge unit? The wiring harnesses and electronics did change from 03+, but if its aftermarket, you should be able to make proper wiring adjustments to make it work. The CAI should bolt up fine, and the short throw should work as well.
Old Sep 20, 2012 | 03:36 PM
fhadso's Avatar
fhadso
Ok. It's an aftermarket head unit. And yes, I love my short throw too much to just let it go. Thanks.
Old Sep 20, 2012 | 03:43 PM
darthroush's Avatar
darthroush
Section Moderator
I believe those wiring harness adapter thingies you buy for aftermarket HUs cover 2000-2005 Neons, so you should be GTG if that's what you used.
Old Sep 21, 2012 | 08:50 AM
03neonRT's Avatar
03neonRT
If you haven't already, do yourself a favor and get some new shifter bushings while your at it. Crazy what a difference such an innocuous piece of rubber can make..
