Burning Oil
Old Nov 18, 2012 | 05:36 PM
George Dorn's Avatar
George Dorn
security reasons
Old Nov 18, 2012 | 05:56 PM
steak59's Avatar
steak59
1 quart a week is pretty freaking bad. Do you see any oil in the PCV hose? maybe there is too much crank case pressure. If that's not the case, he probably did something wrong with the Ring installation. Like forgot an oil control ring on one of the piston?
or accidentally snapped the ring when he trying to pound the piston, I've done that myself a few times.
Old Nov 19, 2012 | 02:15 AM
arnonefrank13's Avatar
arnonefrank13
when you rebiuld a motor your supposd to use a break in oil for so long. maby its suppost to burn it at 1st? i donno, check to see if your oil filter still has its gasket
Old Nov 19, 2012 | 04:13 PM
George Dorn
security reasons
Old Nov 19, 2012 | 04:31 PM
darthroush's Avatar
darthroush
Section Moderator
If you have another connector on hand, it would certainly be the best fix. I also added a little extra thread sealant to my new oil pressure sensor when I replaced the old leaky one.
Old Nov 19, 2012 | 08:12 PM
richards83's Avatar
richards83
Sounds like excessive blow by. Either too much pressure in the crankcase from the combustion chambers or it's not venting properly and I'm surprised your plugs haven't fouled out. Have you checked the pcv valve? I would think worn rings, but if they're new, then possibly the ring gaps weren't staggerred properly, which would suck, but I would definately do a compression check.
Old Nov 20, 2012 | 12:12 PM
George Dorn
security reasons
Old Nov 24, 2012 | 11:44 AM
George Dorn
security reasons
Old Nov 29, 2012 | 11:48 AM
George Dorn
security reasons
Old Nov 29, 2012 | 08:06 PM
richards83's Avatar
richards83
That's crazy. How many miles do you drive per week?
