Zero fuel pressure
Old Oct 2, 2012 | 11:43 PM
Lukeyluke's Avatar
Lukeyluke
Originally Posted by cheapez
Sorry, to confused you.
I only said that as an example of a leaky fuel injector, if the system still has some pressure in it.
No problem. Again, thanks for the info.
Old Oct 3, 2012 | 06:34 PM
Moparkyle's Avatar
Moparkyle
Fuel pumps have a 1 way check valve, if the check valve fails then pressure drains back into the tank.
Make sure you aren't leaking any externally either.
Old Oct 3, 2012 | 11:14 PM
Lukeyluke's Avatar
Lukeyluke
I did not know that. So if the valve fails the fuel would still get pumped up to the rail? The car starts after four or five tries and idles ok. When I have to accelerate it bogs the engine down really bad. To drive it I have to accelerate very slowly.
Maybe the pump is going bad and the valve is defective.
No leaks.
Thanks for all the tips guys.
Old Oct 4, 2012 | 07:49 PM
buddhaman's Avatar
buddhaman
Pump is dead. Same thing happened to my wife's car.
Old Oct 6, 2012 | 01:37 PM
Lukeyluke's Avatar
Lukeyluke
You were right the pump was dead. I installed a new pump and car started right up, runs great and accelerates superb.
BTW, the fuel pressure regulator comes with the new fuel pump.
Old Oct 6, 2012 | 01:39 PM
Lukeyluke's Avatar
Lukeyluke
Thanks to everybody that helped out with my situation. I hope this will help out others in the future
