Vibration, EVAP, RPM Drop
Old Oct 10, 2012 | 01:01 AM
idgie's Avatar
idgie
Originally Posted by jeffjager
It's now allot better! However the main issue remains, idle dropping low (about 500RPM) and the car vibrating when that happens at stops (only in gear). The car works perfect otherwise. If you tap the gas it goes back to idling higher (about 800RPM) without vibration until the next stop.
I'm thinking bad idle control sensor?
I'm somewhat new to the forum and I'll post my issues in another post but this is exactly what my 2005 SXT is experiencing. Exact to the word. This may be a Neon thing.
Other than this, I have a crankshaft code (P016) as well as vibration. The virbation gets much worse once the AC is on. I haven't tried the heat yet. The code is showing even after I replaced the crank. I'm taking it to my mechanic tomorrow or Thursday.
-idg
Old Oct 19, 2012 | 10:54 PM
jeffjager's Avatar
jeffjager
Oops!
Old Oct 20, 2012 | 12:20 PM
jeffjager's Avatar
jeffjager
Oops!
Old Oct 20, 2012 | 03:10 PM
arnonefrank13's Avatar
arnonefrank13
I have vibrations too. I did replace both strut mounts. I used ANCHER mounts from O'riellys. I did notice there was no wieght on the bottom one but the stock one had more mettle on the front of it. and the top one I just unscrewd the wieght and put it on the new one....I think thats why the vibrate....that 3 oz of aluminum..lol I dont know... my rpms at idle are at 700-800 and my stering wheel vidrates a lil only in park. I have now replaced the motor mount nor the tranny one.
Old Oct 20, 2012 | 03:12 PM
arnonefrank13
Correction --- I did not replace the motor mount or tranny mount
Old Oct 21, 2012 | 03:35 AM
darthroush's Avatar
darthroush
Section Moderator
I think the engine mounts are bad. Just found the "rear mount" you are speaking of Darthroush! I'll replace it with my timing belt which is in the same area, I'm at 105,000 now so it's about that time anyway. Wish I had pictures of the mount locations weeks ago. So here are pictures for others that read this:
Here is the "Rear" engine mount:
http://ww2.justanswer.com/uploads/ro..._030318_t5.gif
Here are the torque mounts:
http://ww2.justanswer.com/uploads/GA...4234_mount.gif
Here is the transmission mount:
http://cdn.2carpros.com/automotive_p...8022303b_1.jpg
Wish me luck!
Spend the extra money and get an OEM rear mount!
Old Nov 20, 2012 | 08:17 PM
jeffjager's Avatar
jeffjager
Oops!
Old Nov 20, 2012 | 08:27 PM
steak59's Avatar
steak59
I've seen problem with the Power steering switch causing lousy idle RPM, because it is not sending signal to the PCM to request RPM increase.
When you Turn the steering wheel, does the RPM kick up a little? If it does, then ignore what I just said.
Old Nov 21, 2012 | 01:00 AM
jeffjager's Avatar
jeffjager
Oops!
Old Nov 21, 2012 | 04:14 PM
steak59's Avatar
steak59
RPM does kick up when I hit the limit of the steering rack. I've been tapping the gas very lightly instead as that is easier.
The RPM should kick up everytime you try to steer, especially when you are not touching the gas, like when doing parallel park. Maybe it is ur problem. You can try a switch, it is a cheap item.
Here is your switch, at the rack and pinion.
