A little help please, My car died between an intersection today...
Old Nov 20, 2012 | 12:29 PM
bobisme2005's Avatar
bobisme2005
Unhappy A little help please, My car died between an intersection today...
Alright, here is what I know.
Car dies and immediately turns back on with a subtle jerking action.
Check engine codes:
p0441
p0700
p0755
p0562
Old Nov 20, 2012 | 01:08 PM
George Dorn's Avatar
George Dorn
How's your transmission fluid? How is your drive belt? Is it there?
Old Nov 20, 2012 | 06:04 PM
bobisme2005
Transmission fluid and belt are up to par.
I change the fluid about two weeks ago.
Old Nov 20, 2012 | 07:56 PM
Moparkyle's Avatar
Moparkyle
https://dodgeforum.com/forum/showthread.php?p=2513453
P0441 is completely irrelevant in this scenario.
Old Nov 21, 2012 | 08:06 AM
cheapez's Avatar
cheapez
P0700 is only there to let you know something is wrong with your transmission. It has sub codes stored in the TCM. You need a scanner that can pull those codes in the TCM.
Old Nov 21, 2012 | 08:18 AM
cheapez's Avatar
cheapez
You don't have to worry about p0441
p0755 is p0700 sub's code.
It says shift solenoid B malfunction.
What is the year of your car?
P0562 is System voltage low
You have low battery, or the alternator is not charging it. I replaced the alternator's brushes on my Camry. It worked for me.
Old Nov 21, 2012 | 01:27 PM
bobisme2005
Its a 2003.
Would I possibly have to change my Transmission Solenoid pack?
Old Nov 21, 2012 | 08:52 PM
cheapez's Avatar
cheapez
Originally Posted by bobisme2005
Its a 2003.
Yes, possibly. But, check for wiring and connector first.
You did not have a problem with your car shifting before right? So, wait to fix code P0562 first.
Something else could have set P0755.
Old Nov 21, 2012 | 09:28 PM
cheapez's Avatar
cheapez
From eHow. I think you got your answer to this problem.
The most basic factor that can cause a solenoid shift malfunction is a corroded or loosely connected battery cable. The problem can also arise if the positive (or red) battery cable is damaged in some way.
Read more: What Are the Causes of a Shift Solenoid Malfunction? | eHow.com http://www.ehow.com/how-does_5038986...#ixzz2CukLB5DI
Old Nov 22, 2012 | 12:39 AM
Moparkyle's Avatar
Moparkyle
Did you read the link I posted?..
