03 Neon SXT- Engine Rebuild/Replace Questions
Old Nov 28, 2012 | 09:25 PM
SR71's Avatar
SR71
Default 03 Neon SXT- Engine Rebuild/Replace Questions
2003 Neon SXT 2.0L Auto
192,000 miles
I've had this car for several years and put alot of highway miles on it. Overall, it's been a good, reliable car. Did the Timing Belt at 99k. Struts, Trans Solenoid.
For the past few weeks, upon starting it up, there is a lower end knocking for about 30 seconds, then it goes away. No smoke. Some oil consumption and minor dripping.
I'm considering replacing the engine (cheaper option than buying a new or used car).
MoPar engine w/head is $1700 (employee cost). Found a local guy (lic.mech.) who will change the motor for approx. $500.
QUESTIONS:
While I'm doing this, I'm considering replacing the trans since the mechanic will be dropping the entire front cradle assy. Any suggestions/sources for a rebuilt/replacement trans?
(MoPar is $1700).
What else? Front suspension is noisy, probably should do CV joints, cradle mount bushings, control arm/ball joints, tie rods. Any other suggestions?
Appreciate the feedback.
Thanks!
John
Old Nov 28, 2012 | 09:41 PM
SR71's Avatar
SR71
While some may suggest, junk the car, Neons are throw-away-cars, buy another used car, buy a new car...
I've considered all the options. Buying new is out... $17k minimum/depreciation/payments.
Buying a used car... what are you going to find for $2-$3k that will not have high miles? Plus, another used car is like starting all over again. How long will this one last?
For $2k or so, I will essentially have a 'new' car again for another 200k miles.
Very doubtful I'd find a decent used car for $2-$3k that would last that much longer.
If I replace the engine & trans, the other stuff that might wear out is inexpensive or do-it-yourself work. The MoPar engine comes complete w/new cam, internals, timing belt, water pump, oil pump, head assy, etc.
Thoughts?
Thanks!
Old Nov 28, 2012 | 09:58 PM
buddhaman's Avatar
buddhaman
If you do replace the trans, I would suggest a manual. It'll be better on gas, better performance, and less to worry about.
Old Nov 29, 2012 | 11:08 AM
TejasMtnBiker's Avatar
TejasMtnBiker
I went thru the same thoughts, it's nice to not have payments no matter how many repairs I get to do. Make sure that long block come with some sort of warranty if you can get one
Old Dec 1, 2012 | 08:36 PM
SR71's Avatar
SR71
The Neon Engine from MoPar comes with a 3yr/100k mile warranty.
Old Dec 10, 2012 | 12:26 PM
earlyre's Avatar
earlyre
here's my 2 cents, not sure of the differences in parts costs, but:
I've thought about, when the time comes, swapping the NA 2.4 from the PT in(of course along with it's trans, etc), mainly b/c if the timing belt were to go, from my understanding, the 2.4 is a non-interferece engine, unlike the 2.0.(not as big of a deal when the belt goes) and of course everything "should" (again from my understanding) bolt right up, as that's the same motor as the srt-4 neon, minus the turbo bits...
and please anyone feel free to correct me if i'm out in left field....
Old Dec 18, 2012 | 09:46 PM
SR71's Avatar
SR71
The project begins....
- Rmfg. long block engine assembly from MoPar
(valve cover to oil pan, w/timing belt, water pump, gasket kit)
- Rebuild original trans. ($500 labor & parts)
- New MoPar Engine & Trans mounts/isolators (4 total)
- Lower Ctrl Arm assemblies (w/ball joints, bushings)
- Inner & Outer Tie Rods
- Sway Bar Mount Bushings & Link end assemblies
- New Upper/Lower Radiator Hoses
- New Heater Hoses
- New Alternator/AC/PwrStrg Belt
- Plugs, wires
- Thermostat
- Air Filter
- Fuel Filter
- Oil Filter
- Oil Pressure Sensor Switch
- O2 Sensor(s)
- Radiator/Trans Cooler/Lines (if necessary)
Anything else?
Old Dec 19, 2012 | 09:08 AM
cheapez's Avatar
cheapez
Your car will run like new after you rebuilt it.
The same reason we did not sell our Neon to buy another used car in the $5,000 range. It will just be another crappy car.
You drive old cars, you just have to learn to fix them.
Old Dec 19, 2012 | 04:09 PM
TejasMtnBiker
very true, too bad these automatic models were Turbo'd like some of the older dodge 4 banger automatic turbo'd models.
