04 Neon not firing on 1&4, 2&3 good
Old Dec 27, 2012 | 02:28 PM
Dabuga's Avatar
Dabuga
Default 04 Neon not firing on 1&4, 2&3 good
Anybody know what is causing my problem, trying to help out a friend in need and I am looking for a confidence boost as these hi tech cars is not really my cup of tea. I am just an everyday back yard mechanic from the 1955 Chevy days.
Changed coil,(was the start of he problems as it cracked and shorted out) plugs (they were really warn, never changed) and wires, (they were questionable) checked Continuity on the pulse lines from the PCM as well as possible grounding and it is all good. When re-connected to the PCM I get a constant ground showing on the black/gray wire feeding the coil. Does this mean the computer (PCM) is bad? Mahalo/Thanks George
Old Dec 28, 2012 | 03:39 PM
mirandaneon's Avatar
mirandaneon
bump bump
Old Dec 29, 2012 | 04:56 AM
Dabuga's Avatar
Dabuga
No help as yet, don't understand bump bump. OK thanks anyways...Aloha!
