iac stuck
Old Jan 8, 2013 | 06:23 PM
tschay's Avatar
tschay
Default iac stuck
i have a 2000 i was cleaning my idle air control valve the needle was out then i dropped it the needle got pushed in and wont come out i put it back the engine revs up to 3000 rpms and im pulling 3 codes p1684,p0123 &p1193 so is there a way to free theneedle or is it a paper weight tschay
Old Jan 8, 2013 | 08:09 PM
Moparkyle's Avatar
Moparkyle
Paper weight.
Probably not a cheap one.
Old Jan 8, 2013 | 08:40 PM
tschay's Avatar
tschay
ok thanks tschay
Old Jan 8, 2013 | 11:31 PM
Neonewbie's Avatar
Neonewbie
Thats why I am afriad to touch any thing lol I have a habit of making things worse.
Old Jan 10, 2013 | 05:22 PM
TejasMtnBiker's Avatar
TejasMtnBiker
just gotta keep tryin and never give up =)
Old Jan 11, 2013 | 12:09 PM
tschay's Avatar
tschay
Question
so i went to a junk yard got an iac valve it is the same part except the numbers on the part mine is 04861000AD the one from the yard is 04861000 does anyone know what the AD means and will it work thanx tschay
Old Jan 13, 2013 | 12:49 PM
Moparkyle's Avatar
Moparkyle
No clue, was it off a 2nd gen Neon?
Old Jan 13, 2013 | 04:26 PM
darthroush's Avatar
darthroush
Section Moderator
Looking up both of those part numbers online shows me an IAC that doesn't go on a 2nd Gen Neon. This is a non-illustrated part, but the price and description match the correct part: 05014116AA is what I get for the correct IACV.
Old Jan 26, 2013 | 09:47 PM
tschay's Avatar
tschay
Unhappy
i was on my way to work this morning the car is reving between 3000 and 1000. so i drove it home drives fine as long as it is above 3000 rpm's do u think the iac is the problem. it drove fine for a little while so don't forget it is an iac from a junk yard the same size engine it was a dodge a different throttle body probly a gen. 1 idon't know i have never seen a gen. 1 thanx tschay PS i got a code P1299
Old Jan 27, 2013 | 02:50 AM
Moparkyle's Avatar
Moparkyle
Probably.. I believe P1299 translates to "vacuum leak detected" for Chrysler. A stuck open IAC would cause that.
