did a compression test today..
Old Jan 16, 2013 | 01:17 AM
arnonefrank13's Avatar
arnonefrank13
Cool did a compression test today..
First of all I went to autozone and rented a compression tester for $40. Went home and did a dry test. the results were really low. So I did a CT on the Ford Focus, got the same reading...so I returned it to Autozone and told them the equipment was faulty. Then I went to Orielly's and rented thier CT for $40. and I got accurate readings with thier's.
Cylinder no 1 - 190
Cylinder no 2 - 175
Cylinder no 3 - 182
Cylinder no 4 - 180
That was a dry test. wasn't gonna do a wet test. We all know how neons are...
Old Jan 16, 2013 | 02:09 AM
darthroush's Avatar
darthroush
Section Moderator
You only need to do a wet test if there is a discrepancy in the dry test results. 7.89% variation while the manual says anything up to 25% is acceptable. Your engine isn't worn out yet.
Old Jan 16, 2013 | 07:56 PM
Moparkyle's Avatar
Moparkyle
How many times did you crank the engine when you tested it?
Old Jan 17, 2013 | 01:07 AM
arnonefrank13
5 times each cylinder... i have 235k on that motor
Old Jan 17, 2013 | 01:33 AM
arnonefrank13
hey Darth..how did you come up with the 7.89%? I was trying to figure that out but couldn't.... let me know the math brother. thanks.
Old Jan 17, 2013 | 02:12 AM
darthroush's Avatar
darthroush
Section Moderator
To find the percent of variance between two numbers, the equation is:
((A-B)/A)*100
A - High number
B - Low number
So: ((190-175)/190)*100= 7.894
Old Jan 17, 2013 | 08:48 PM
arnonefrank13
oh wow. thanks Darth!!
Old Jan 17, 2013 | 09:24 PM
darthroush's Avatar
darthroush
Section Moderator
Mhm, you're welcome!
