Hub Nut
Old Feb 25, 2013 | 12:14 PM
Spitz's Avatar
Spitz
Default Hub Nut
What size socket is needed for the rear hub nut? ( 2004 )
I'd like to have the correct one on hand when I go to remove it.
Thanks
Old Feb 26, 2013 | 10:33 AM
Spitz's Avatar
Spitz
Anyone know the size?
Old Feb 26, 2013 | 11:33 PM
darthroush's Avatar
darthroush
Section Moderator
Use a caliper?
Old Feb 27, 2013 | 09:28 AM
Spitz's Avatar
Spitz
Lol... I think you've massively missed the point. Check my previous post.
I'm a member on another car forum....typically they scramble to be first to shout out a nut/bolt size etc.
Old Feb 27, 2013 | 02:42 PM
darthroush's Avatar
darthroush
Section Moderator
You want to know what size it is. Measure it with a caliper and you'll know. What point did I massively miss? I've never touched the rear hub nut and apparently not too many others have either based on the number of replies. That leaves two options unless I'm wrong: measure it [with calipers] or Google it. If you search correctly, I'll bet ya the answer is in one of the first three results.
Old Feb 27, 2013 | 05:54 PM
TejasMtnBiker's Avatar
TejasMtnBiker
I always use a 22in. cresent wrench, bad habits are hard to break I guess
Old Feb 28, 2013 | 07:58 AM
AnthemBassMan's Avatar
AnthemBassMan
-What I found online was it took a 30mm socket. May or may not be. Just be sure to have a couple sizes handy when you change the hub.
L8R,
Matt
Old Feb 28, 2013 | 09:02 AM
Spitz's Avatar
Spitz
Darth....read my first post agian....massively missed the point ...yes.
Thanks for that Anthem
Old Feb 28, 2013 | 10:28 PM
AnthemBassMan
-Sure thing. And don't forget. The hub nut needs to be torqued to 160 ft. lbs...
L8R,
Matt
Old Mar 1, 2013 | 09:00 PM
Spitz's Avatar
Spitz
Hub arrived today..yea.
From what I can see...they use ball bearings instead of rollers...no wonder they wear out quickly.
I have torque wrench at the ready....160lb's..."check"
