01 dodge neon
Old Mar 11, 2013 | 11:09 PM
rachet2290's Avatar
rachet2290
New Member
Default 01 dodge neon
i bought an 01 dodge neon for my girlfriend and needless to say it needs a bit of work . i bought her some led windsheild wash spray nozzles and i wired them up to a switch and they wont work right when the leds are on the switch is off and when the switch is on the leds are off ive tried switching the wires around but i cant figure it out . a little help would be nice. anybody have i deas to what is goin wrong?
Old Mar 12, 2013 | 03:28 AM
darthroush's Avatar
darthroush
Section Moderator
Ground and power wires switched on the switch?
Old Mar 12, 2013 | 10:16 AM
rachet2290's Avatar
rachet2290
New Member
I have the power wires on the led washer nozzles coming from the battery to an inline fuse the negative wires together. The power wires go to the switch and the negative wires to the acc on the switch and the switch grounded and if i ground the leds every wire gets red hot. Ive tried switchin the wires up and im still having the problem of when the light on the switch is on the lights are off and when the lights are on the light in the switch is off
Old Mar 12, 2013 | 10:30 AM
rachet2290's Avatar
rachet2290
New Member
75 views and only one person is tryin to help ineed help anybody have an idea to what is going wrong bby with these damn led washer nozzles?
Old Mar 12, 2013 | 01:27 PM
TejasMtnBiker's Avatar
TejasMtnBiker
If thee are getting hot you have something crossed or a resistor for the leds is missing, sometimes the manufacturer forgets... 4 leds wired + to - will replace a resistor.
Do your wires get hot wired directly to the battery or 12v source? If so it's missing a resistor, return them, or supply your own from radio shack or an electronics shop.
http://www.hebeiltd.com.cn/?p=zz.led...tor.calculator
