Idle Help w codes
Old Mar 15, 2013 | 05:21 PM
Ryan.youngii's Avatar
Ryan.youngii
Default Idle Help w codes
I have a 2003 Dodge Neon SXT 5 speed and I am having a problem with my idle being way to high. It sits at right about 2k rpm's. I just replaced my TPS and now the idle is way to high. The check engine light is on as well but it is just emissions p0420, p0703 for a brake switch and p0441. Any suggestions or has anyone else had this problem or something similar? Thanks
Old Mar 16, 2013 | 02:20 PM
TejasMtnBiker's Avatar
TejasMtnBiker
There's a lil adjustment process you need to follow & use a digital volt meter. It's easy once you test it a few times
https://dodgeforum.com/forum/2nd-gen...volt-idle.html
Old Mar 16, 2013 | 07:53 PM
packfan88's Avatar
packfan88
did you connect all the air intake properly?
i misaligned the duct to the throttle body last weekend so it was sucking straight air when i started it up. revved high (not sure how high the rpms were) so i shut it off and went to see wtf. just had to seat it properly and tighten it up.
Old Mar 21, 2013 | 09:12 PM
Moparkyle's Avatar
Moparkyle
Make sure there are no vacuum leaks.. Could also be an idle air motor stuck.
Old Mar 30, 2013 | 03:03 AM
arnonefrank13's Avatar
arnonefrank13
make sure the idle adjustment screw is set to your preferance ( its a lil bolt that acts as a bump stop for the throttle cable). I couldn't find it for like a month. lol
