Hit bump, no starter, no spark
Old Apr 11, 2013 | 07:59 PM
civicvtec17777's Avatar
civicvtec17777
Default Hit bump, no starter, no spark
I hit a bump in my 02 neon the car shut off, i pulled over, tried to restart the car and it wont even crank over, we jumped the starter.to get it to crank but it wont start, no spark, all the lights on the dash work along with the dome lights blinkers etc....
Any ideas? Automatic 2.0
Old Apr 11, 2013 | 08:31 PM
buddhaman's Avatar
buddhaman
Try disconnecting the battery for a few mins then reconnecting it. If that doesn't work, switch your horn relay with the ASD relay. When the computer senses a hard enough shock (like a wreck or hard hit from a bump), it kills power to the starter, coil pack, and fuel pump.
Old Apr 11, 2013 | 08:55 PM
civicvtec17777
Ok i will give that a try, im sure its easy to find but do you know where the ASD relay is located? Thank you, any other solutions out there incase that dont work
Old Apr 12, 2013 | 08:09 AM
buddhaman's Avatar
buddhaman
It's in the fuse box by the battery.
Old Apr 12, 2013 | 01:06 PM
Ryan 20's Avatar
Ryan 20
Also check the PCM Connectors.
Old Apr 12, 2013 | 02:26 PM
civicvtec17777
Where are the PCM connections?
Old Apr 12, 2013 | 04:30 PM
Ryan 20's Avatar
Ryan 20
On the driver side, facing the car to the right of the radiator. Also check the ASD 20 amp fuse and other fuses.
Old Apr 13, 2013 | 12:43 PM
civicvtec17777
Ok just getting to work on it today
Old Apr 14, 2013 | 09:07 PM
civicvtec17777
After a big panic checking everything it was a 20 amp fuse
