back up
Old Apr 24, 2013 | 09:09 PM
tschay's Avatar
tschay
Default back up
hi again to all i have a 2nd gen dodge neon i recently found out my back up lights are not lighting up in reverse. i tested the sockets with the car in reverse and got nothing out of both sockets. i had also found my rear defroster dosent work.
thanx,tschay
Old Apr 25, 2013 | 02:59 AM
darthroush's Avatar
darthroush
Section Moderator
Could be a bad neutral safety switch. You might check power at that switch first and see if you are getting anything. As for the rear defroster, have you checked the fuse?
Old Apr 25, 2013 | 06:28 PM
tschay's Avatar
tschay
Question helplease
darth could u help? could u tell me wher it is located please
tschay
Old Apr 26, 2013 | 03:19 AM
darthroush's Avatar
darthroush
Section Moderator
ETA: Looking at the wiring diagrams, you may first check fuse 7. It is a 15A fuse that should be labeled as the rear defroster fuse. The thing is, that fuse also controls (in part) the neutral safety switch and back up lamp switch (which is part of the neutral safety switch).
You have a 00-01 Neon (non-electronic transmission), IIRC, yeah? It's a three-prong connector.
