Removing a/c
Old Apr 27, 2013 | 03:55 PM
Neonproject12's Avatar
Neonproject12
Default Removing a/c
SO the a/c compresser is bad now it squeaks loud. I just want to take it out because i dont use it anyways even when it did work. Do i just put the belt back on as if it was not there (so smaller belt) or get the delete kit for srt?
Old Apr 27, 2013 | 08:49 PM
Moparkyle's Avatar
Moparkyle
You might be able to find a bypass pulley. Or finding a smaller belt may work too, but that will be some work.
Old Apr 28, 2013 | 01:32 PM
Neonproject12
Do you know where I could find a bypass pulley? & I found a srt delete kit for the a.c but idk if it will fit the r.t. Do you know if I'd be able to just run the belt from the power steering to UDP?
