How do I make my 2nd Gen neon faster.
#21
RE: How do I make my 2nd Gen neon faster.
I found for power I put in cold air intake, header, down pipe, muffler, msd coil and plug wires,under drive pulley, a camgear, and motor mount inserts. For handling I put springs, front and rear strut tower bars, some polly bushings. And for stopping slotted cross drilled rotors.
#23
OK so I am checking EBay out. Mods I want are as follows.
Interior
SRT4 Seats (stock ones are crap)
maddog shifter (where to get it, and do I need a SRT4 shift boot and ****?)
Suspension
SRT4 springs, shocks and struts
front and rear strut tower braces
SRT4 brakes all around (is it possible on a non-ABS car with rear drums, and if so what do I need off the SRT4 to get it done)
nice bigger and different wheels and tires( NOT SRT4 WHEELS)
Engine
CAI
55 mm Throttle Body
header and full exhaust
Exterior
black euro headlights
black euro taillights
new rear trunklid with the Downdraft rear spoiler
And I think that covers it. Basicaly I am looking for a better handling, better braking and a little faster than stock daily driver. With the exceptions of the SRT4 seats and the shifter boot and ****, the other appearance items are not a big deal.
Thanks,
Gary
Interior
Suspension
Engine
CAI
55 mm Throttle Body
Exterior
Thanks,
Gary
#24
hey people./. just signed up to the sight...and as this topic mention our first thought after purchasing a neon.... how can we go faster. well i have a o4 sxt automatic 2.o l4 16 valve neon.... so far. mods consist of
-fully synthetic oil switch over..
-msd coil..(was told i should gap my sparks bigger since the msd coil produces bigger spark..i have one of those coins lookin gappers(n e help)???
-bosch wire set..
-champion sparks...
-k&n typhoon cold air intake as well as changed oil filter to k&n as well..
-magnaflow high-flow dual muffler...(hate that fart can honda sound...this magnaflow provides a real nice low bassy sound i like) ....
-radiotor flush/treatment.and refill
-full tune-up and flush and fill of all oils
here is my big question.. what else can i get... so far i been thinkin about these thinkgs. please help me out and give all the tips and ideas possible.. from cheapest to highest mods....also lookin to maintain the car as well as run it hard when i need too....thanx.. it;s a everydau drive car with about 35,000 miles on it..
-under drive-pulley.. seen some on ebay for about 20-30 bucksa. figure it would be ok for now til i get more change for a unorthodox pulley. unless u guys suggest other wise..
-motor mounts..seen some prothane ones. i think or somehting like that...
-lowering springs(ne suggestions)
-throttle body..i think mine stock 49..or 52mm... not sure... can u guys tell me the stock throtle size on my 04 sxt neon? and suggest max safe size throttle body
-street/strip body valve((looking.. n e suggestions)
-shift kit for a auto matic 4-speed(n e suggestions?
-pcm sent to jet performance
-lookin for a exhaust system were i can still use my magnaflow dual muffler....new filter for transimmision)
hope to get much feedback....and just incase u guys need help findind parts or anything. i've got tons of top neon sites.. hit me up. thanx...
-bosch wire set..
-champion sparks...
#25
well man i've got a 04 sxt and so far i only have a intake and exhuast. I recommend that you go with a short shifter, better get the mopar one, underdrive pulley ( the ones on ebay are no good and will do more hurt than good get a afx), prothane motor mount inserts and maybe some other stuff. I'm going to get my jet chip installed today. You can find most of the good parts on howellautomotive.com or modernperformance.com, those are the best sites to order from.
#26
ORIGINAL: AirWolf
I have a auto 2004 sxt neon and my first mods were k&n drop in cone filter and srt4 exhaust, mopar performance wires and platuimn champion plugs and soon to have a intake and also have nitorus and will have a hahn turbo. Because of the stupid computer in the 03-05 good luck with the performance.
hey...i have the same type neon... have you learned n e other tips or tricks about the car i should know about....
[IMG]local://upfiles/29306/37F4AF504CD146158D80F94700CA5A66.jpg[/IMG]
#29
#30
A mod tip list that Customlimitz863 found...
Fidanza Cam Gear - The nuts stick out very far, they can be stripped, there are just too many points to loosen then tighten down when adjusting the timing...
Alternative - Get an AEM
AF/X Bobble Strut - Known to slip out of preload, known to bind up, known to cause excessive vibrations, known to just overall be a pain in the *** to work with...
Alternative - Get a Booger Bobble
Eibach Sportlines - They will blow struts, the ride is just too harsh... Unless your car is a show car, do not get these springs (even when used with KYB's)... Consider getting coilovers...
Alternative - Get High Rates
MPP DOHC ECU in a SOHC Car - Unless your going to tune the fuel, this combo isnt worth it by any means... Personally I would just save up the money and jump to an AF/X Race (unless your gas is junk, your area is very hot, or you live in a very high climate, then stay with MPP)...
Cam Timing (SOHC) - A basic thing to keep in mind is that when you retard (pull backwards) the cam timing it will give you more top end power, and when you advance (push foreward) the cam timing it will give you more low end power... This isnt always true and of course depending on your engine setup this may vary... At times you can adjust your cam and actually loose power instead of gaining power... As always proper tuning should be done on a DYNO and once a Adj. cam gear is installed its always best (and safest) to install it at Zero... And more isnt always best, pulling back or pushing foreward the cam timing can result in power LOSS... Use a Dyno... Remember when installing a SOHC gear, torque it down at 85' LBS to the cam...
Note On Crane Cams - When installing a cam gear the cam may not want to just slip right into the cam gear... This is a problem that alot of people have had to face, I have noticed its best to get it on a little then work it on with the bolt that holds it into place... That way it slides on strait... If you ever want to take it off, a small pry-bar works very well, and rock the cam off... Use some 3in1 oil and let it penetrate a little... Be smart, you can damage the cam gear or cam by doing this...
Basic Cam Specs (SOHC) - Different cams give different amounts of power at different times, on different engines... The cam from a 95 neon will give some power, then its the Crane 0010, which is pretty much not worth the money... The Magnum Cam is pretty nice, and very cheap, if you get a Magnum I reccomend getting a valve spring upgrade... Then you have the Crane 0012 which makes a little bit more power then the Magnum but not so much that people get it over the magnum due to the cost... Crane 0014 should be used with raised compression engines, turbo engines, high nitrous motors, definitely get a valve spring upgrade... There are several companies that make cams, but the ones listed are currently the most popular purchased... Titanium retainers are not required, most dont spend the money on them, stock retainers work fine...
SOHC Rockers - The stock rockers on the Neon SOHC are roller rockers with hydraulic adjusters from the factory, so dont worry about upgrading your valve train to roller rockers, it already has them...
Porting SOHC Manifold - If you have a SOHC you can actually port your manifold pretty easily (all SOHC's came with plastic manifolds, except for some 96's) just get a dremel and some sanding tips and go to work... If you port the runners, you can take out the injector humps... Just be sure to fill the little divots above them with some JB weld and let it cure over night or you will go through the top of the manifold...
Headers - There are alot of different ones... Usually the longer the better... Mid length headers give good mid range, some low end, a decient top end... Long tube headers give alot top end, good mid range, almost nothing low end, short headers, they give a little everywhere... CERAMIC COAT your headers... Even if they come triple knickle plated, have it ceramic coated inside and out... This will keep it from rusting and coloring... Plus it will hold heat in better... This is another thing you dont want to go cheap on if you want performance, if you want to go fast, you will want a long tube...
Stay away from JET computers or any "chip" you solder into your wiring harness... It wont provide power... Most advertise injecting more fuel to create more power, how can this be when Neons already run rich... Same goes for any TB risers or Tornado's... Iceman Risers do help to avoid puddles as well as TB risers if you have an Iceman...
Fuel Injectors - Go with stock fuel injectors at all times UNLESS you have a built turbo car that you need the extra fuel... If you do, have a built turbo project, you should be smart enough to know what injectors you need... If your car doesnt have a turbo you dont need different injectors... Stock ones work PERFECTLY...
Spark Plugs - Stock champion coppers work perfectly... Some say NGK's work well also... Just stay away from the splitfires, or +4's or Platinums... Keep the heat range stock unless you have nitrous you might want a colder plug...
Spark Plug Gap - Gap your plugs at .035 or .040...
Spark Plug Wires - Stock works great, if you have a problem with your wires, then go ahead and upgrade... If you do get upgraded wires Magnecores are very well manufactured, but I would have to say to go with MSD wires... I have had Magnecores loose the clipping ability when snapping onto the spark plug, my MSD's work great...
Removeing Power Steering (a.k.a. "P/S") - If you want to remove it, you can either loop the lines at the rack, or leave them open... Pulling the belt is one way of producing more HP, but its gonna' be a pain to turn unless you loop the lines or cut the lines... Once you loop or cut them, turning will be ALOT easier...
Aluminum Flywheels - As always reduceing the rotational mass a vehicle has will increase power, or atleast allow the potential power to be applied... Aluminum flywheels are a great way of reduceing the rotational mass from the crank... Fidanza makes a great flywheel, I have had NO problems with it at all, ever... I have even rebuilt the clutch and used the same flywheel... Spec offers a flywheel that although is light has its problems... Mopar00Neon and NeonHooligan (both personal friends of mine) installed a spec flywheel into Hooligans neon... The threads on the flywheel would not accept the bolts for the flywheel... It looks as though the threads were made then cut over... Damageing the first two or three threads... Nothing chaseing the threads with a tap wont fix, but you shouldnt have to do this in the first place... Stick with Fidanza...
Big Weight On The FMM (Mass Dampener) - Its a ski, so that when your dumb *** hits a curb you dont smash too much of your car... You can take it off for weight redux... DO NOT REMOVE THE FMM, REMOVE THE WEIGHT UNDER THE FMM!
Brace From Oil Pan To Tranny - Its to reduce vibration and just let the car be smoother... It doesnt weigh anything so I kept mine on, I noticed it also helps to prevent dirt into the bell housing...
Brace Going Across (under) The Back Seat - Leave it there, you will thank me if you ever get in a wreck...
Metal Plates Where Your Knees Are At In The dash - If you ever get in a wreck, this prevents your knees from going into the sharp, crooked, jagged area under the dash... Basically it keeps your knees from turning into hamburger meat...
Weight In Center Console - Take it out if your ever in there... It doesnt do anything...
Manually Shifting An ATX - Dont do it! If you must get quicker for a brisk stop light race, or to end the quarter mile a little faster put the car into 2nd and leave it there until about 80mph then shift it into D... Manually shifting first gear will not make you any faster... Manually downshifting a ATX is very bad for it, dont do it trying to look cool and make it seem like you have a stick...
Wanna' be faster in an ATX? - Brake torque... Hold down the brake and hit the gas, dont do it for more then about 20 seconds or so, then let off the brake... DO NOT rev your car in Neutral then drop it into Drive...
ATX Tranny - If you have an ATX tranny install an aftermarket tranny cooler... Especially if the vehicle is raced at all, or driven hard at all... ATX trannys die out prematurely when the tranny gets really hot... If you have an ATX, install an ATX tranny cooler...
