clutch pedal
Old Jul 18, 2013 | 09:16 PM
jamesneon2003's Avatar
jamesneon2003
Smile clutch pedal
I have a 2001 dodge neon, manual clutch. does that model have a clutch switch. was wondering cause I have to really press the clutch pedal to the floor...to start the car.. the clutch was put in a year ago by mechanic. only put 10,000 miles on it
the car shifts great.. any ideas and where would the clutch switch be located
Old Jul 18, 2013 | 09:58 PM
fhadso's Avatar
fhadso
You have to push the clutch in all the way to the floor to start it. The switch is just a simple button that gets pressed by the pedal when you push it to the floor. There isn't really a away around this, other than relocating the switch but starting your car without the clutch all the way in not only is bad for your engine/transmission/clutch, it's also a safety hazard.
