Help I can't figure it out
Old Feb 17, 2014 | 09:22 AM
73novass's Avatar
73novass
Default Help I can't figure it out
I have a 2004 neon 2.0 auto I just put a new cat converter in and both o2 sensors. drove the car and now I get a dead pedal every once in a while??? I hit the gas and it boggs down it never did this before. I keep pumping the gas pedal it comes back and drives off great no codes are thrown.
Old Feb 19, 2014 | 01:19 AM
73novass's Avatar
73novass
Cool
bump for help
Old Feb 26, 2014 | 09:39 PM
TejasMtnBiker's Avatar
TejasMtnBiker
dead pedal after only the 02 & cat r&r? Did you try a few pcm resets pulling the fuel pump fuse
Old Feb 26, 2014 | 10:20 PM
73novass's Avatar
73novass
yes still nothing, although my air temp sensor on the air box was disconnected and reading 29 degrees and I placed it back in the air box and after resetting the obd 2 several times it was running great then after about 30 minutes or so parked it and my wife drove it and she said it is doing the same thing again.. I guess I will try an air temp sender for the heck of it maybe the one I have is now bad from being disconnected and getting dirt and rain on the tip of the sensor.
Old Feb 28, 2014 | 01:59 PM
73novass's Avatar
73novass
ok that wasn't it. took off the iac and cleaned it out not it what the heck???
Old Mar 3, 2014 | 05:27 PM
73novass's Avatar
73novass
Angry
new plugs installed it runs better but not right yet. going to try wires and then the throttle position sensor if need be.
Old Mar 3, 2014 | 08:04 PM
the18301's Avatar
the18301
Take off your CAMSHAFT sensor on the transmission side of the head and check if the silicone seal on the outside of the sensor is not clear and see through, if it's brown/yellow the sensor with not pick up timing right and you will lose correct timed ignition.
Old Mar 3, 2014 | 09:00 PM
73novass's Avatar
73novass
thanks for the advise but I changed it out about 1 week ago it was leaking oil. but I will say I would not of thought of that thanks. when I put the new plugs in it ran great for a day I of course moved the plug wires so I will do that when I get a chance and I did tap on the throttle position sensor so that will be my last piece I guess.
Old Mar 3, 2014 | 09:04 PM
donsnideriii's Avatar
donsnideriii
my 97 ram was acting similar to that, replaced the tps sensor and the prob went away
Old Mar 3, 2014 | 09:07 PM
donsnideriii
try unpluging the tps and see if it still does it
