Stock Sway bar MM size
Old 02-23-2014, 03:44 PM
MJSchutt's Avatar
MJSchutt
MJSchutt is offline
Default Stock Sway bar MM size
Hey, I'm looking at replacing the sway bar bushings on my 03 SE.
There are a lot of different MM sizes that i can buy, what is stock?
I'm also replacing the end links and have a lot of different length options, what are the differences / advantages / disadvantages?
Also, any recommendations while I'm down there?
Old 02-26-2014, 09:13 PM
sbhawaiian's Avatar
sbhawaiian
sbhawaiian is offline
I did my 2000 last year and the front was either 20 or 22mm. The sway bar was easy to get to so I put a small crescent wrench over the bar to take a measurement. The wrench and SAE and metric readings but you can also just measure the distance. I believe mine was she smaller 20MM bushings. The bushings were intact but they were hard as a rock. I replaced them with prothane bushings and used the grease that came in the kit.
Old 02-28-2014, 02:46 AM
MJSchutt's Avatar
MJSchutt
MJSchutt is offline
Just took my calipers home from work and measured it up. It's 22MM on my 03 SE
Quick Reply: Stock Sway bar MM size
