Question HELP NEEDED PLEASE-- 2001 Dodge Neon Problems ????????????????
Old May 16, 2015 | 08:29 PM
shanda's Avatar
shanda
Question NEW****Where do I go to post a question
I need to ask some specific questions in regards to my 2001 Dodge Neon's recent act up. First time user, please be nice, I would greatly appreciate any and all legit help. I thank you kindly.....
Old May 16, 2015 | 08:33 PM
shanda's Avatar
shanda
I know that it is sending out a code in reference to the catalytic converter and I am thinking that it may possible need to be replaced, pretty upset over that....However, it is also recently losing an awful lot of power....The power loss increases as the drive continues. It will take about a quarter mile before it has trouble picking up speeds over low gears of first and second.....It is an automatic, by the way.
Old May 16, 2015 | 08:36 PM
shanda's Avatar
shanda
I need to ask some specific questions in regards to my 2001 Dodge Neon's recent act up. First time user, please be nice, I would greatly appreciate any and all legit help. I thank you kindly.....I know that it is sending out a code in reference to the catalytic converter and I am thinking that it may possible need to be replaced, pretty upset over that....However, it is also recently losing an awful lot of power....The power loss increases as the drive continues. It will take about a quarter mile before it has trouble picking up speeds over low gears of first and second.....It is an automatic, by the way.
Old May 16, 2015 | 08:38 PM
shanda's Avatar
shanda
Question Question HELP NEEDED PLEASE-- 2001 Dodge Neon Problems ????????????????
Old May 16, 2015 | 08:45 PM
You want this section. Welcome to DF!
If it's whining about the cat, and you are losing power, chances are real good the two problems are related. A clogged cat WILL rob you of power, and if it gets bad enough, the engine won't even run. Any exhaust shop should be able to pressure test your exhaust.... that will tell you if the cat is bad.
Old May 16, 2015 | 10:24 PM
What is the code?
Old May 16, 2015 | 10:32 PM
shanda's Avatar
shanda
P0420
Old May 17, 2015 | 01:03 PM
Either O2 sensor or converter. I'd start with the cheaper of the two first.
Old May 17, 2015 | 01:23 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
Mieneke and Midas converters are cheap.
Why are you "pretty upset" that a 15 year old car needs a converter?
If you keep driving it like that, you're going to cook the engine.
Old Sep 6, 2015 | 05:36 PM
boatmoter's Avatar
boatmoter
the converter may be clogged causing a exhaust restriction which will cause the engine to lose power and more the longer you drive it,eventually it will not move at all
