brakes noise and getting water inside car
well this happended to my since last 3 weeks ago. everytime i back up the press the brake pedal i here this cranking noise coming from the front bottom of the car. like something metal is broken or about to. i checked the brakes assembly and pads and everything seems to be ok. does anyone have expirence something like this?? what else sould i check to detect this noise?
another question is that if someone really found the cause of why everytime it rains the car soaks water. mine get really wet in front pessenger bottom part and rear as well, and i checked the bottom of the rear seats and is also wet. my trunk too. i put some sealer during the summer but it seems that it stills the water find its way to get in. i hate that part, and i know is a common problem for this cars. i have an 04 srt neon. i havent checked the sunroof that can also helps the water get in. im really pissed and dissaponted with this issue in my car. car smells all the time. right now here in NY we are getting rain everyday since like 4 days ago and the car keeps getting water inside everyday. what can i do??
The water is probably coming in through your taillights. The seals go bad. Your spare tire well will fill up and it will also run down the groove in the metal of the body into the passenger compartment and soak your carpet in there. You need new taillight seals and to remove all the seats and carpet to properly dry it out and prevent mold.
yeah, the well tire space get like a pool qith lots of water. i saw some water leaking trhough there but water mut go through behind the carpet cuz right behind the tailights there is no water. ama fix that thing right away. i hate the smell.
well i kinda fixed the problem with the water leaking. checked some vids and they say that usually is the seal around the taillights that go bad. i ch ked mines and thet look the original to me so the previous owner didnt do anything about it. so i just add another layer of weather stripping kinda thik and use some 3m double tape and also add some rvt glue to the edges so water couldnt have any way to get in between the plastic and the seal. i hopa that works. i haven't cheked cuz it hasn't rain but i hope it works
