Power steering Trouble??
Old Jan 2, 2016 | 01:19 PM
Ssvegeta96's Avatar
Ssvegeta96
Default Power steering Trouble??
Hi all just got a 2005 neon 162xx miles manual sxt i think.
Works nice for 500 bucks 8)))))))))
Anyways got the car 2 days ago. Wanted to get a feel for the car and its noises and subtleties. so at idle i or at stop i rolled the windows down and listened for stuff. I would hear a wine noise at idle or stop in neutral dint think much of it. I was driving on the freeway yesterday night and the steering got super hard, when I parked it i saw the power steering reservoir had overflown. Thankfully I took pics seen below. Also im I missing a belt ? I coulda have sworn this thing needed a belt to drive the power steering pump? Any advise on what it could be before i start ripping stuff out would be appreciated. I read some where i might need to drain it and clean the reservoir and mesh filter inside and see if that does the trick???
Thank you all in advance
Old Jan 2, 2016 | 03:43 PM
richards83's Avatar
richards83
Yes, you are missing the belt. The pump can't work without a belt, so if you install a belt, chances are it will be fine.
Old Jan 2, 2016 | 04:05 PM
Ssvegeta96's Avatar
Ssvegeta96
Thank you for the reply bud. Real quick i drove this bad boy for maybe 13 miles probably give or take to park it at my home. Do you think i did irreparable damage to the rack and pinion or something like that ?
Old Jan 2, 2016 | 09:50 PM
Ssvegeta96's Avatar
Ssvegeta96
Default Update
If anyone is interested. I added a belt (correct one i hope auto zone lady seemed off) but it keeps snapping off when i turn on the car. Either the tension pully is weird or one if the other pullys is loose?
Old Jan 9, 2016 | 12:25 PM
Ssvegeta96's Avatar
Ssvegeta96
Update: Replaced tensioner idler pulley since it was crap it had melted broken off and replaced it and added the belt and wallah.
made some videos but there already a handful of good ones out there that i followed. Took me a while but i did it.
