installing a new head, do I need to add more oil ?
Old Aug 11, 2017 | 09:21 PM
mike L's Avatar
mike L
Default installing a new head, do I need to add more oil ?
When installing a new rebuilt SOHC cylinder head do I need to add more oil ? Looks like the parts have some oil on them. I was just wondering if I needed to pour some oil before added the valve cover. Thanks
Old Aug 12, 2017 | 03:05 AM
darthroush's Avatar
darthroush
Section Moderator
If the dipstick shows you need oil, then add some.
Old Aug 12, 2017 | 04:38 PM
mike L's Avatar
mike L
I meant do you normally have to add a little oil on the cam until the oil gets there at start up.
Thanks
Old Oct 13, 2017 | 05:14 PM
mike L's Avatar
mike L
Originally Posted by shaneret
Dude,
It's called Assembly Lube.
Please, if you can.Have somebody with engine knowledge look at that for you.
The rebuilt heads from Advance A didn't look like they had any assembly lube when it was rebuilt that's why I was asking. Some new valves were added and it was decked. So I ending up pouring oil all over the valve train. I turned the engine by hand a few times without the spark plugs in. I changed the the engine oil and filter. I kept out the fuel fuse and turned the engine over a 10 seconds to get more oil on the valve train. I plugged in the fuse and started the car and checked the compression and got 185psi on each cylinder. No trouble codes.
Old Oct 15, 2017 | 11:51 AM
mike L's Avatar
mike L
Default burnt exhust valve
So so very sorry. I apologize for my disrespect.
After that being said.
Very Good job.
Did it need new head? Or are you going for a performance boost?
Going to Dyno it?
None taken. I have never done this before, but I'll take anything apart. I did a lot of research first, you tube videos and Haynes manual and questions here. It was a burnt exhaust valve. It was a repair for my daughter's car.
