Can I do a compression test without the wiring connected?
Can I do a compression test without the wiring connected? I installed a cylinder head and what to check compression before adding everything back on. The starter main wire is hooked up. Wire ground to the head is hooked up, next to the battery. Fuel relay is out. Coil is not connected. There a large green wire in front can't remember were that goes I think to the bottom of the starter for the wiring 2nt ground. The intake is not on. Does the psm come into play to turn the engine over for test ?
Why wouldn't the test check how the valve seal to?
