Driveline Vibration When Turning Right
Old 02-12-2018, 12:59 PM
paw paw's Avatar
paw paw
paw paw is offline
OK, good find, fix, feedback & to hear the OEM tranny mount has finally put the fix on your right turn vibrations after replacing the top side mounts with after market.
Of note, in your 1-3-18, #17 post, you indicated that you replaced the top passenger side mount with OEM, so does that mean now only the left/drivers side top mount is after market?
  #22
Old 02-12-2018, 01:09 PM
CrashBandit's Avatar
CrashBandit
CrashBandit is offline
Correct, the top and bottom mounts/struts are aftermarket.
  #23
Old 02-12-2018, 01:29 PM
paw paw's Avatar
paw paw
paw paw is offline
Drivers side both top & bottom are after market & Passenger side top & bottom are now OEM? This is good info for me, as I mentioned earlier our 2000 is likely to need new mounts soon, so it's likely to be OEM for me too.
  #24
Old 02-12-2018, 01:35 PM
CrashBandit
Correct. Right side/Front mount and transmission/gearbox mount are OEM.
  #25
Old 02-12-2018, 01:38 PM
paw paw's Avatar
paw paw
paw paw is offline
Ok thanks for the good clear feedback, so that seals the deal, when it's time it'll be OEM parts for me too.
  #26
Old 02-12-2018, 01:46 PM
CrashBandit
I purchased the two OEM mounts from https://www.moparpartsoverstock.com/ They seemed to be cheaper than my local dealer for whatever reason. By the time you do yours there may be a better deal somewhere else on OEM parts.
  #27
Old 02-12-2018, 02:06 PM
paw paw's Avatar
paw paw
paw paw is offline
Dang I forgot 3 times now, is yours auto, or manual tranny?
  #28
Old 02-12-2018, 05:36 PM
CrashBandit
Manual Tranny.
  #29
Old 02-12-2018, 05:41 PM
paw paw's Avatar
paw paw
paw paw is offline
Ok Manual tranny, that's good info for others doing searches for a like problem to have when finding this thread.
