2005 Neon crank no start
Old 01-29-2019, 11:27 PM
barracuda340's Avatar
barracuda340
barracuda340 is offline
Default 2005 Neon crank no start
Hi, Crew! I've been racking my brain about this for weeks. I have a 2005 Dodge Neon crank no start. I have no supply or signal voltage to any of the three wires to the coil. Crank and cam sensors are working and communicating with the PCM properly. There is proper fuel pressure and functioning injectors with proper supply and signal voltage. I have continuity between the supply wire for the injectors, coil, and to the PCM. The ASD relay is good. I am at a loss as to why there is no voltage to the coil. I don't have anything to show waveforms of the PCM. Just a test light and a multi-meter. Any help is greatly appreciated.
Old 01-30-2019, 08:00 PM
primem's Avatar
primem
primem is offline
2 L engine I assume?
the coil should only have power on the dark green/orange wire in the number 2 pin of the coil connector.
the asd relay supplies power to the all injectors and coil on the same wire. check for power on the coils...if they don't have power....move back to the asd relay and see if you have power out of the relay. Is the asd relay clicking? check for codes...maybe you have a code for the asd circuit?
if the crank or cam position sensor input is missing the pcm will shut down the asd relay.
Old 02-09-2019, 04:32 PM
Dave_w's Avatar
Dave_w
Dave_w is offline
I have the same problem. I've replaced the coil, cam and crank sensors. It was starting if I would shoot a little either to it but then one day just wouldn't start at all. I'm not getting any codes. Is there any help or hope for this?
Old 02-09-2019, 06:32 PM
primem's Avatar
primem
primem is offline
start a new thread and post your model, year, engine and a clear description of the symptoms.
Quick Reply: 2005 Neon crank no start
