Random idle miss when cold
Old Jun 16, 2019 | 11:15 AM
  #21
paw paw's Avatar
paw paw
Originally Posted by 2004 Neon SE
The coil I took off was a MasterPro brand from O'Reilly, I was told, by an O'Reilly employee no less, that brand of ignition components aren't the best quality.
And you confirmed that for you it wasn't the best quality. It's secondary resistance was within range but its primary resistance was 4 times the specified value.
Did you measure the Salvage coil pack for its resistance values, or have its output bench tested before you used it? If so it would be interesting to hear what you found.
Old Jun 16, 2019 | 04:02 PM
  #22
2004 Neon SE's Avatar
2004 Neon SE
I just bolted the one I got from the salvage car,didn't test anything. But since it runs smooth as it should, I'm happy. The coil pack I took off was put on by previous owner, but I did hang on to it in case I need it
