transmission switch atx to mtx
You will have to add several things, like a clutch pedal, clutch slave cylinder and master cylinder, shifter assembly and cables, and maybe a center console. Another problem you'll run into is doing away with the trans controller. Your pcm is not configured to a manual trans.
never really thought of doing it. i mean a buddy of mine replaced his 5 speed tranny in his wrx to a 6 speed but i never thought of how much work it would take to switch an auto to a manual. how much do you think it would cost to go about doing it yourself, after you had gotten everything and, would you need a same model and year. i mean i have a 2001 atx and would i need a 2001 mtx? can you guys let me know how to do it how much it would cost after pcm and everything like you said. thanks guys!
