2004 Neon SXT turbo!!
Old Jan 25, 2006 | 03:38 AM
evo_neo's Avatar
evo_neo
Default 2004 Neon SXT turbo!!
Hey guys, I purchased a turbo kit for my 04 neon sxt it is a garrett t3/t4 super 60 setup.
before i install the turbo, what other upgrades should i add for optimum performance and
to protect my engine from getting messed up?
Thanks
Old Jan 25, 2006 | 11:36 AM
tooslow's Avatar
tooslow
Default RE: 2004 Neon SXT turbo!!
clutch is good also you can upgrade the oil pump and if you want too put down some power maybe built your bottom end.
just make sure you get some extra feul for that beast and everything will be alright.
Old Jan 25, 2006 | 11:58 AM
whyte69's Avatar
whyte69
I'd be careful with how much torque you're pushing. Anything too crazy will start to mess up your stock internals. I've read that the stock internals don't last long after 200 hp. If you haven't already done it, I'd look into doing it before you get too crazy.
Good Luck with the turbo, post pics and results once you're done, I'd love to see how it turns out.
Old Jan 25, 2006 | 06:58 PM
insanetuner18's Avatar
insanetuner18
hey check out modernperformance.com they have complete engine rebuild kits incase you would install a turbo
Old Jan 25, 2006 | 07:06 PM
lblackneon's Avatar
lblackneon
If it were me I would have rebuilt my bottom end before I received the turbo. Don't go too high on rpms just to be safe and nicer to your engine. What other mods do you have to your car?
Old Jan 25, 2006 | 11:08 PM
casper's Avatar
casper
The top end is more important unless you are going all out, then they are both important.
Old Jan 26, 2006 | 12:58 PM
tooslow's Avatar
tooslow
ORIGINAL: casper
I think it is the other way around the only thing the top end will do is reduce or increase lag time basically.
Old Jan 29, 2006 | 02:03 PM
evo_neo's Avatar
evo_neo
The only performance mods i have are a cold air intake and exhaust but thats it on performance
Old Jan 30, 2006 | 09:19 PM
Altima_wb's Avatar
Altima_wb
ORIGINAL: tooslow
ORIGINAL: casper
Actually you are wrong the cylnder head is where all the power is made it is what makes or breaks an engine its where most engine builders will spend the most time and money to extract power.... Yes you have to have a sturdy bottom end to make a ton of hp but you won't have a ton of hp without a good head...
