JET Proformance Chip
Old Feb 10, 2006 | 01:45 AM
  #31
03neonRT's Avatar
03neonRT
Default RE: JET Proformance Chip
I usually seem to get the most power after I hit 4500 when my secondaries open up...
Old Feb 10, 2006 | 01:51 AM
  #32
minidodge32's Avatar
minidodge32
yeah mines exactly like you guys. I'm thinkin about gettin a limited slip differential but idk if that will help with my take off. Any suggestions
Old Feb 10, 2006 | 01:53 AM
  #33
sauceboy's Avatar
sauceboy
i'm in the same boat, ur, uh... car. anyways. yeah, at 4000 rpms and beyond its crazygonuts. before that it's kinda slow going. i was hoping for a little more poop out of the lower rpms. looks like this may just be the way. (still waiting to see if the pcm steals his fun away, though)
Old Feb 10, 2006 | 02:50 AM
  #34
BDM's Avatar
BDM
Thanks for all the info guys. I'm definately getting this thing. By the way I forgot to ask an important question. Does this thing increase the rev limit above 4k? Or does it stay the same. Eitherway...this thing sounds sweet.
Brian
Old Feb 10, 2006 | 02:56 AM
  #35
LowSlowNeon's Avatar
LowSlowNeon
I'm assuming you have an auto tranny? If so...why would you want it to rev higher then that? It will more then likely just spin the tires if you try and take off any harder then that. ****...I spin my tires and have traction problems at 2000rpms in 1st gear most the time......If I tried letting it rip at 4,000rpms there would be a lot of smoke at least on the street. On the track I've let it rip at 4k before. Spun the tires quite a bit with some smoke...but I grabbed traction pretty quick. On the street it would just be a burnout.......So to answer your question...I'm not completely sure. But if you want to go anywhere going above 4k launching probably won't help you unless you have good tires and a LSD.
Old Feb 10, 2006 | 04:05 AM
  #36
BDM's Avatar
BDM
hehe yeah I know...
I wasn't wondering because I was planning on dropping it from that high. I was just curious. And yeah I have an auto.
If I get this, where should I go to get this installed? What kind of shop did he go to exactly? Should I go to Dodge mayby? Hopefully I can get this thing out myself...
Old Feb 10, 2006 | 04:49 AM
  #37
Customlimitz863's Avatar
Customlimitz863
why cant you dyno run it.l with and without chip. cant you dyno it b4 u sedn you comp in. then dyno it once the jet stage 2 is secured in your system? im lookin for a decent priced dyno arounf the kissimme orlando area. if n e pointers? help? thanx...............
Old Feb 10, 2006 | 05:18 AM
  #38
BDM's Avatar
BDM
We got the 180 thermostat stock already right guys? No one ever clearified that. Still wondering where I should get this installed at too.
Old Feb 10, 2006 | 12:19 PM
  #39
04 mo neon's Avatar
04 mo neon
Did you buy yours from jet or another company that sells jet chips? Link please
Old Feb 10, 2006 | 12:32 PM
  #40
03neonRT's Avatar
03neonRT
I think he bought his from Howell Automotive for $260...
